Cit / Pug Engines
- Contact:
it should do. I believe the 1.6 in the 405 was the same block as the visa/205 gti but it only had single point injection so was 85bhp or something like that. It would bolt straight in but you have to think about stuff like possibly needing the wiring loom, ecu, are the fuel pickups the same and so on. Also if its an early 405 with a be1 gearbox then reverse will be up to the left and so you may need to modifiy gear linkages etc.
what specs your 1.4? is it injected single point i guess, 75bhp? simplest thing may be to try and find a smashed up ax gti (not gt) on ebay which had the 95 (or 100??) bhp 1.4 which is probably your engine but with multipoint injection and a few other changes which would probably be a simpler task.
re: r5 seriously doubt engine mounts are the same and yes its a 1.4 but if you mention the T word they will request you bend over and give them your bank account etc
- Contact:
I mean the much talked about ZX with the "racing" engine in thread:
http://www.andyspares.com/discussionfor ... C_ID=10527
Don't worry about getting confused easily, it wears off with age! (i.e. you don't remember enough to worry about forgetting it).
//NiSk
//NiSk
There're two 2.0 16v engines available in the Xsara which, judging by the pictures in the handbook, are substantially different.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rossnunn</i>
STOP!!!!<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> Oh, ok. [;)]
- Contact:
- Contact:
