How hard/long is this job?
Just to give an indication of the language i'm speaking - i'm happy fo do diskpads, spheres, wheels and change the hydraulic fluid and oil but the last time I did anything much more than this was taking the head off my Morris Minor and various odds and ends on my Renault 16 about 25 years ago.[:I]
BX drive shaft gaiters
- uhn113x
- My Cars: 1981 Dyane - on road all year round.
1982 GSA Pallas - on road April - September.
1997 ZX 1.9D Dimension. - x 1
Hi Anthony
Not too bad, if you mean the outer ones, and if your BX is not one with the one-piece shaft and CV spider.
You need to remove the hub nut, disconnect the drop-link, and take the stub axle off the bottom of the strut.
Use proper Ligarex strapping, not tie-wraps, even if these are what is supplied. It is worth dismantling and cleaning out the joint, if you have time, but do not wash the parts in solvent.
