its time to change my girlfriends car and i am looking at a 106 or Saxo diesel (shhh but the smaller the car the less likely she will knock the edges of )
anyway i have never had either of those cars before is there anything dodgy i should be looking for in particular? (other than my girlfriends right hook if she reads this )
cheers
peter
Getting a 106 or Saxo
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
oh yes it was going to be a veggy beast
mad not to nowadays when fuel could go to any mad price it wants
astonishingly difficult to get sellers to tell you what fuel pump their car has ...even when i explain the differences they are not that keen to lift a bonnet and look (or take a photo)
result ... got a x reg saxo with as bosch pump for £800 on ebay...
a supplementary question for anyone that can help.........
i didnt get an owners manual with the car so i am a tadge puzzled by one of the instrument icons
when i turn the ignition on on the left hand side of the instrument panel a yellow square with what looks like a key going into it lights up and then disappears.
what is this indicating? its a poverty spec one so no central locking or remote plipper unit ...just the good old key in the door....
is it telling me a immobiliser is disabled, or is this some other sort of eccentric citroen message?
cheers
peter
cheers
peter
Thats the immobiliser light. There is still a chip in the key (even though no central locking) that will 'talk' to the ECU via a transponder on the ignition surround (most likely position)
The light going out signals all is well. If you try to start it and it flashes whilst cranking, the immobiliser is kicking in which could be due to various issues, usually that it is not receiving the correct signal or no signal at all.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
cheers for that ... i presume that means it would be rather expensive to get a spare key for it.....
