I've motorized my rear blinds! ; link to pics now
Thought id improve on the BX rear blinds by motorixing them. All you need is a 100:1 fixed ratio reduction gearbox and 12v motor from Maplins, some fishing wire, some pullys and some screws and a double pole double throw switch mounted in the centre console next to the handbrake. Its brilliant for when it gets sunny on the move or if some idiot is too close behind with bright lights. I thought id find out if such a thing exist in the World of cars and it does, but is usually a £300+ option on expensive Mercs and BMW's etc. The motor and gearbox screws intothe underside of the Parcel shelf, the fishing wire wraps round a shaft I made and attatched to the motor, then emminates through an invisable (because of the carpet) hole, goes up to two little pullys at the top and spilts into two lines, one going left the other right to two other pullys, and back down to the hooks on the blinds. You probably think ive got too much time on my hands-I havent, im just mad!!
- fastandfurryous
- Location: On the road, travelling at high speed. Meep Meep.
- x 4
Think it is 30 Ibs wire. Probably more than necessary. The blinds dont tend to drop back down although I havent taken the car anywhere yet- I dont think they could due to the fact that the gear ratio is so low that you cant turn the output shaft at all yourself. Infact I would have got a slightly quicker less forceful gearbox and motor if id have known how slow it was but I thought id play it safe and get one I knew would lift the blinds-They dont feel that hard to pull but with two of them and the friction of the fishing wire etc it takes quite a lot to pull them up. Basically they take almost twice as long as the electric windows to go up and down, while being very slightly quicker on the way down. Ill take a picture when I get the chance and post it.
Right I dont know how to put these pictures on here but ive found something called MSN "Myspace" on MSN messenger where I have uploaded pictures of it- Its really nothing special to look at- I took one of the blinds in the halfway up position and one of the motor and shaft unit.
http://spaces.msn.com/members/BXWORLD/P ... c=blogpart
Hopefully that should work- They are there somewhere and there is also a button to see a bigger version of each picture.
