306 help
306 help
ive just bought a 306 and ive done something with the immobiliser and it wont let me start the car!! when i turn the key the red light is on when i enter my code the green light comes on and they both stay on? i entered my code twice trying to change it to something i would remember but this has happened!!
any advice on this would be appreciated! ive been told it might be in programme mode?
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
Red & Green lights on at the same time means a problem.
Is the keypad beeping quickly & the red light flashing? Does the keypad have a "D/N" button or a "S" button?
Check the fuel supply safety switch hasnt tripped under the bonnet, Its a big push button under either a black or red rubber cover, Just push it to reset it if it has tripped.
Check none of the fuses have blown in the fuse box.
Come back after you have checked these things out & report your findings.
yeah i turn the alarm off with the fob but soon as i turn the key the alarm goes off!! when i try to start the ignition it used to tick over as if it was starting but now its just dead?
what i thought to do was disarm the battery and when i reconnect it it may let me enter a code without both the lights staying on as ive been told this might be 'program mode' so this may take it out of this??
Past:
The keypad imobiliser DOESNT stop the engine turning over on the starter.
The car alarm if armed WILL stop the starter turning the engine over & will also stop the keypad from allowing codes to be entered.
It might be worth charging the battery up off the car overnight & seeing if this helps solve your problem.
