Page 1 of 1
Xantia LHM tank dis-assembly and cleaning (French)
Posted: 29 Mar 2010, 21:16
by rmunns
I found this. Very good for pictures and (page 2) diagram of components.
http://www.forum-auto.com/marques/citroen/sujet2406.htm
Posted: 29 Mar 2010, 21:32
by Xaccers
Handy tip for removing the resevoir:
Once you've removed the two 10mm nuts at the back, move the airbox out the way and use a long wide screwdriver or pry bar under the resevoir to pop it out.
Much easier than trying to tug it out and spilling LHM
Posted: 30 Mar 2010, 08:20
by MJM
There's a nice diagram of the steering column showing the universal joint which occaisionally needs attention on page 2, as well.
PS The forum clock is still on winter time.
