A/C Not very cold.
- New User
- My Cars: This is a dummy account added to fix some orphan posts.
A/C Not very cold.
Evening everyone, Have been out today with the A/C on but it isn't as cold as it was last summer. I'm due for a long drive in France soon and I would like to sort it before hand. For the record the outside temp was about 28-30 degrees. Last year it was so cold sometimes I had to turn the A/C off but now it's nothing like that. I have done a search but my only thought was a regass which may not be the problem looking at other post's. Just a note this is the first car I have ever owned with A/C and I'm not that familiar with it's operation.
My aircon has been great today, When did you last have it regassed?. Also if you dont run the aircon every so often (I run mine for 10 mins a week) it can lose its gas. I'd suggest getting it serviced, old gas removed and system 'vacced' pressure tested and then refilled if the pressure test shows up now leaks.
Paul.
Paul.
- New User
I didn't have recycle on (forgot about that). I only got the car last summer but judging by all the things I've had to do since owning the car (full Citroen service history hmmm!! what do they do on a service?) I would say that the A/C has never been touched so I think that a test at least is in order. Thank's for the replies.
Yes, Alec. Your a/c guy is right. THis is due to a characteristic of modern refrigerants. Because your aircon is actually working, albeit at low efficiency, I would advise you to look on Ebay where the popular Interdynamics refill and measuring systems are now becoming available. Fully discharged systems need another technique but partially filled ones will benefit from home regassing, which is no longer a black art. The kit and refrigerant will cost about £35.
Be happy: it is a way of being wise. (Confucius.)
'92 TZD Estate(Grolliffe), Gone but never to be forgotten.
'95 405 GLX TD Estate. too new to name.
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
This is due to the different characteristics of R134a which has a higher discharge pressure (I'm told) The a/c is less effective in a traffic jam but on the road, it is a freezer.
- New User
This year has been better but I am using it more. I didn't last fear as my wife wanted fresh outdoor air but with her hayfever being worse this year the aircon is on and windows shut. I did explain that the air drawn into the aircon is from outside and is also pollen filtered so is probably better than fresh "open window" air.
