Injectors misbehaving but trying to understand the numbers
Rhothgar
Donor 2023
x 85
Re: Injectors misbehaving but trying to understand the numbers
Post by Rhothgar »
darbuck wrote: 25 Aug 2023, 12:07 Big time I wilet you know how I go I am going to go after the coolant harness first and work back from there I think. I printed off a the relevant stuff I can find so far and will go from there next.
Sounds like a plan.
Don't labour the engine though. See if it starts and move on if it is not immediately running sweet.
darbuck
Donor 2023
x 147
Post by darbuck »
Yeah good advice will do.
Darren
darbuck
Donor 2023
x 147
Post by darbuck »
darbuck wrote: 14 Mar 2023, 19:33 Hi Lads I ran a diagnostic on the car because she smells fuelly, yes it's the C5 that has all the problems but I bought it thinking it had an injector problem. Can anyone tell me what the us stands for. To me none of the injectors look right numbers wise but I am hopeful if being corrected. No fault codes apart from the glow plug fault but we know that is a ghost code
Hi all, trying to get on top of a fueling issue. Car smokes white badly at mid range RPMS smells fuely at idle. Leak Off is between 20 to 25ml per 3 min interval. A couple of question.the numbers are approximately the same as the image above. I did note timing is retarded by -5 degrees I don't know how relevant it is.
What is the expected leak off on Delphi injectors on a dwb10 engine?
I couldn't get the injectors to code so would this cause the white smoke?
How do I input the replacement injector codes which are the cross referenced type given the ECU won't accept it I think they have an extra digit?
Darren
darbuck
Donor 2023
x 147
Post by darbuck »
Ok got them to code using Delphi scan tool. No white smoke far less fully I will take readings later to use as a base condition. Just abody work and a few bushings in the back to do now and then I can finally book her in for NCT 😃.
Darren
darbuck
Donor 2023
x 147
Post by darbuck »
I sorted the glow plug light staying on needed a new relay. So now no preheat codes either and light goes off nearly as quick as it comes on.
Darren
Rhothgar
Donor 2023
x 85
Post by Rhothgar »
What are your new readings on the leak-off?
shtu
Donor 2023
Post by shtu »
Going back a little to the question about "us" - Microsecond.
https://en.wikipedia.org/wiki/Microsecond
darbuck
Donor 2023
x 147
Post by darbuck »
Sorry Roger I haven't had a chance to do one yet but I will over the next week.
Darren
darbuck
Donor 2023
x 147
Post by darbuck »
Yeah I had a brain fart on that.
Darren
darbuck
Donor 2023
x 147
Post by darbuck »
Rhothgar wrote: 12 Apr 2024, 15:44 What are your new readings on the leak-off?
Hi Roger, finally got to do a leak off 1,2,4 had approx 20ml after minutes and 3 had 25ml. The limit is apparently 37ml according to the fold version of Citroen doc back up I have. So I think we can safely say well within spec. I'm waiting on tyres for the rear and I need to give her a good clean and then it's going for NCT. So on the home stretch after what had felt like a lifetime of work.
Darren
KennyW
x 132
Post by KennyW »
Darren,
Your almost there, keep it up.
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
x 1348
Post by MattBLancs »
As above, got to be on the home straight now, good luck with the NCT :)
darbuck
Donor 2023
x 147
Post by darbuck »
Thanks lads gave the interior a clean last night. Getting excited now 😃
Darren
ekjdm14
x 223
Post by ekjdm14 »
Epic read, this one. Epic struggles too, you've definitely earned a sweet running reliable car so fingers crossed that's what you end up with.
'97 306 XS 1.6i, Blaze Yellow, 24k
'96 ZX SX 1.9TD rolling shell, White, 81k
darbuck
Donor 2023
x 147
Post by darbuck »
Thanks ekjdm14 yeah a lot of work and a lot of money, more than the car is worth by a lot, but I know it's going to be good when I am finished.just finished painting the bumpers which got scratched when they were off the car and the rear wheel arch and passenger side rear door which had bit of damage. I made a mistake and bought too big of tyres for the front so I am waiting on a set from my mate. The 225/17/60's leave a gap of 10mm between the arch liner and it needs to be 20mm for the test so no good. apart from that and a wheel alignment she should be ready for the NCT now, hopefully she will pass 🤞
Darren
