[FIXED] P1352 FAULT
- x 5810
Re: [FIXED] P1352 FAULT
No problem, the relay boxes do fail, so shouldn't be too difficult to confirm once the other checks have been done.
After verification the first step, which is : "Check the continuity and insulation of the electrical harnesses between the pre-heat glow plugs and the pre-heat unit".
I have identified, when I put my black lead of the multimeter to the battery "-" and touch by the red lead the hole (pin relay sit place) of the bottom relay part (mother bottom connecter) which is supposed to be connected to the glow plug (according to the pins location). I read some value but after it immediately shows me OL, which is pointing to the open circuit if I understand correctly. I did it for the 4 glow plugs pins, but the result was the same. Seems, I need to investigate it more...
