Heyo, happy bank holiday weekend.
I have lost the clamp for my dpf pressure sensor pipe.
Are you able to find that for me? It's a sort of u shape with a bolt that goes through it. It holds a metal line that goes from the dpf to the pressure sensor. Kind regards
- x 20
- x 5806
Let me know which item on Diag A or Diag B
Diag A
Diag B
Diag A
Diag B
- x 20
Will be Diagram B 71&18
- x 1022
71 is bolt M6 x 1mm x 20mm (part no 692395 @ £1.46).
18 is the clamp, part no 1714R4 @ £10.73
- Donor 2023
- x 5
Good evening. Looking for par numbers for Anti roll bar bushes and both control arms, may as well change the drop links too.
Many thanks.
Duncan.
Many thanks.
Duncan.
- x 5806
I can't get the OEM Drop Rod Links - they won't allow me to add, so there may be an issue, so these are the alternative and cheaper approved part:
(1) Anti Roll Bar, part: 9802490980, £347.78
(2) Anti-Roll Bar rod, part: 1679755380, £19.78
(5) Nut, part: 9807710580, £0.76
(2) OEM Front Wishbone (Left), part: 9846329780, £121.45
Cheaper Version (Left), part: 1682729680, £40.56
OEM Wishbone (Right), part: 9846329280, £115.46
Cheaper Version (right), part: 1682729580, £47.40
