TOTH Make - Champion
Type - Electric
- x 6084
- Donor 2023
- x 2936
How wrong could you be ?
It's not a lawnmower plug - at least not in this instance It's actually - technically - a rotavator plug ! I think it's a Howard Bantam rotavator.
Although the engine may actually originally be from a lawnmower
If anyone can correctly guess the make and spec of spark plug on their first try then I'll send them a used spark plug as a prize*.
* Terms and conditions apply, the value of your prize may go down as well as down
Sadly no longer a C5 owner
- x 6084
Looks like this to me:
In which case it could be either a Champion Spark Plug 868/RJ19LM or maybe one of Briggs & Stratton 293918, 293923 or 29693?
or of course the NGK equivalent the BR2LM?
- Donor 2023
- x 2936
Wrong, wrong, wrong, wrong on all counts Mick. You're fired !
- x 6084
Thank god for that!! The one thing I definitely don't need is a used spark plug, I've got enough for my motorist's chess set that I keep threatening to make!!
How about a Denso W9LMR-US?
- x 2539
I have it in my head as a Champion J8 or J8c but it could be another makers equivalent.
- Donor 2023
- x 2936
Bloody hell ! Now that is genuinely impressive
I hesitate to ask - but what gave it away, Mr Gibbo ?
Full terms and conditions to my prize offer:
To receive your prize used spark plug, you must supply a stamped addressed envelope to the competition organiser by close of business today.
Make and model of spark plug will be at the judges discretion.
Used spark plug may not be fit for purpose.
No cash alternative.
Your house may be at risk if you do not keep up repayments
- x 6084
Stewards enquiry !!! I said Champion in my first guess and among my list of possibles which is half right, and you said Wrong wrong wrong wrong !!! I shall consider myself un fired and merely misdirected!!
- Donor 2023
- x 2936
The stewards have had their enquiry behind closed doors and they still say you were wrong. The correct make AND model was required and you didn't supply that. So nerr !!
- x 6084
I got the correct make without naming a model in my TOTH guess I shall be referring the matter to the appeal court on the grounds of insufficient diligence on behalf of the stewards, oh and my Dad's a policeman!!
- x 2539
I remember J8s from my earlier days, shorter than the regular length of thread.
- x 6084
Yes well done Gibbo, I recognised the short reach which I think I had in outboard motors when I was manning a sailing club rescue boat!!
- Donor 2023
- x 2936
"And tonight on Mastermind, we have Gibbo from Gloucestercershire.
And your specialist subject is:
'Spark plugs of the British Isles between the years 1942 and 1993' "
- x 6243
- x 4941
Not a good idea to put butter in the microwave for 2' 22" on high
