C5 2008 (X7 ?) Turbo Fault
x 5816
Re: C5 2008 (X7 ?) Turbo Fault
Post by GiveMeABreak »
MikeT wrote: 13 Apr 2019, 16:01I think brake pads is now the last outstanding service requirement needed on this car. I do have new pads for the estate but think the X7 has larger brakes so won't fit?
Part for X7 Disc Pads only is 1619790280
425424 for the Front Disc Kit on he X7.
425346 for the MK II kit
admiral51
Donor 2023
x 378
Post by admiral51 »
Well i did say it was too good a car to break for parts :rofl2:
It passed due to your hard work and patience Mike and i am really pleased she has no advisories =D> =D> =D> =D>
Have you replaced the windscreen or did he miss it :wink:
MikeT
x 232
Post by MikeT »
admiral51 wrote: 16 May 2019, 18:38 Well i did say it was too good a car to break for parts :rofl2:
I don't recall you mentioning the windscreen Colin, remind me?
Check the MOT online :wink:
admiral51
Donor 2023
x 378
Post by admiral51 »
MikeT wrote: 16 May 2019, 22:06
Check the history :rofl2:
MikeT
x 232
Post by MikeT »
admiral51 wrote: 16 May 2019, 22:20
Nothing about the screen when you got it MOT'd 3 times last year, Colin. :)
admiral51
Donor 2023
x 378
Post by admiral51 »
I have never changed the windscreen, seems some testers view things differently lol
Date tested
3 June 2017
PASS
Mileage
98,998 miles
MOT test number
7565 6130 3484
Test location
View test location
Expiry date
3 June 2018
Advisory notice item(s)
Nearside Front Tyre worn close to the legal limit wearing to inner edge (4.1.E.1)
Offside Front Tyre worn close to the legal limit wearing to outer n inner edges (4.1.E.1)
Offside Front Windscreen has damage to an area less than a 10mm circle within zone 'A' small stone chip to lower screen (8.3.1a)
What are advisories?
Date tested
27 May 2016
PASS
Mileage
91,039 miles
MOT test number
9110 3880 1500
Test location
View test location
Expiry date
3 June 2017
Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
under trays fitted
:rofl2:
admiral51
Donor 2023
x 378
Post by admiral51 »
Well just seen the MOT report now that is what i would class as a very observant tester
Monitor and repair if necessary (advisories):
Items removed from drivers view prior to test air freshener ()
=D> =D> =D> =D> =D> =D> =D>
I did try to care of the old Devil Car she is pretty solid just needed your time and TLC and you should be proud of what you have done =D>
admiral51
Donor 2023
x 378
Post by admiral51 »
Well Mike what is your MPG assuming the old girl has not let you down, cannot keep the betting open for much longer :)
MikeT
x 232
Post by MikeT »
No, the car's still functioning without complaint, Colin, thanks for asking.
The brakes need looking at still, they're not as progressive as I'd like. Gentle action on the brake pedal does very little at low speed until the pedal reaches a point when it almost locks up and tries to plant my face on the 'screen.
As for the economy, I can't seem to better 53mpg average.
Best I've seen is 61mpg for a few hundred miles but shop & hospital visits in congested traffic sees it drop significantly.
I think the estate's economy was best in it's just-off-idle torque which the X7 doesn't seem to have. ie, around an uphill s-bend i often traverse, I could leave the estate in 4th gear at 30mph and it would pull it up and round ok. Do it in the X7 and it will labour, lose speed and start to chug forcing a downshift. (Assuming the gear ratios are the same for both cars?)
I can't pull away at idle like the estate does either, or if I did and suddenly needed to floor it there is an embarassing or worrying delay before it gets a move on.
I've also noticed when driving hard, mpg would show low-mid 20's in the estate whereas it drops to mid-high teens in the X7.
So I've started a second bottle of Miller's fuel treatment as the first bottle showed an improvement with the cold-starts.
All this makes me wonder if the turbo actuator length needs adjusting properly as per that video. The mechanic who fitted it told me the best he could do was set it to the same length as the old one.
admiral51
Donor 2023
x 378
Post by admiral51 »
53 mpg is pretty good as an average Mike :)
x 4949
Post by myglaren »
admiral51 wrote: 09 Jun 2019, 12:20 53 mpg is pretty good as an average Mike :)
Considerably more than I achieve.
Donor 2023
x 1391
Post by Paul-R »
Careful, Peter will be along soon to say it's quite low actually!
"Trying is the first step towards failure" ~ Homer J Simpson​
