Is it possible to install latest Citroen C5 Navigation System on older C5?
Moderator: GiveMeABreak
- My Cars: Citroen C5 Tourer Exclusive 2.0HDi
Hi guys.
I wanted to upgrade my 2011 C5 tourer navigation system to a more recent one.
A know the latest C5 had a touchscreen system with mirror link and apple carplay (didn't find the model name).
Is it possible to install this system on my 2011 C5? If so, where can I purchase this system?
Thanks.
Thanks.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5648
Re: Is it possible to install latest Citroen C5 Navigation System on older C5?
Possible, but expensive:
You will need the new screen the SMEG IV2 unit and the central console fascia (as some controls move from buttons), and also this cannot be manually coded using a Diagbox Clone. The configuration can only be downloaded from an official PSA server securely, plus it will also need the Carplay activating. The problem is, there are very few dealers that will do this, because of the problems with having to use another vehicle's VIN to download the correct file and then the manual telecoding to try and get it to work - and main dealers are not likely to do this because of the risk.
Expect to pay anything between from 1500 Euros for the equipment, excluding diagnostic time from a friendly dealer!
GiveMeABreak wrote: ↑04 Feb 2019, 11:50 Possible, but expensive:
Are there no other alternatives to have a Mirrorlink/carplay system while mantaining steering whell buttons funcionality?
Thanks.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No not really as the interface is more than just audio controls, there is all the other control switches for control.
- My Cars: 2010 C5 V6 HDi Tourer
2006 307SW HDi 136
1992 205 GRDT - x 3
I wonder about the BSI activation.
I installed an RT6 unit in my 307 (which went out of production before the RT6 was released!) which works fine with OEM trip computer and other stuff. Doing a normal diagnostic would show a blank for audo/telematics ECU. In order to telecode the RT6, I had to select the car as a 5008 before running the diagnostic. Then, nothing would show up on the ECU list except for the RT6 which I could then configure.
Might it be a similar case with the SMEG2, in that it is possible to configure if you were to choose a car to which it was fitted by default?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
A lot of the SMEG systems were download-only configurable from PSA servers, including the ability for Apple CarPlay options.
- My Cars: 2007 c4 gp exclusive 2.0hdi egs
2008 c2 vts 1.6hdi
1992 xm sed
1984 cx25 pallas ie auto
2000 xantia forte hdi 90
2010 c5x7 2.0hdi 163 vtr+nav (smeg+iv2)
2009 citroen dispatch 1.6hdi
2019 c5 aircross 1.2 puretech - x 1
yes i have just fitted it in my 2010 c5x7
and did it without using diagbox the head unit was programmed by me and is now fully functional pics to follow
lorddevereux wrote: ↑15 Apr 2019, 14:28 I wonder about the BSI activation.
P307 - CAN2004 communication protocol
SMEG - CAN 2010 communication protocol
Unfortunately, you cannot install it. The displayed "Menu" etc. button does not communicate with the system
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1369
But he already says it DOES work.
lorddevereux wrote: ↑15 Apr 2019, 14:28I installed an RT6 unit in my 307 (which went out of production before the RT6 was released!) which works fine with OEM trip computer and other stuff. Doing a normal diagnostic would show a blank for audio/telematics ECU. In order to telecode the RT6, I had to select the car as a 5008 before running the diagnostic. Then, nothing would show up on the ECU list except for the RT6 which I could then configure.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Some confusion here with people talking about different systems.....
lorddevereux is talking about his RT6 - which he installed - but made reference to SMEG at the end of his post, which is what Zolysys is talking about Paul, and this does require a CAN2010 architecture.
- Paul-R
- Donor 2023
Yes but Zolysys referred specifically to lorddevereux's post and even quoted it so I put his reference to SMEG (not SMEG+ or RT6) as a mistake. Anyway, Zolysys can no doubt clear this up as to what he was referring to.
2008 c2 vts 1.6hdi
1992 xm sed
well my c5x7 is running a 2017 smeg iv2 on can 2004 architecture menu buttons and all other buttons on steering wheel work reverse camera now working alert log displays alerts nav is duplicated on matrix display on instrument cluster
i am just in process of getting the jukebox to work
even though all works in global test it shows as ecu not recognised that doesnt bother me as i can program the head unit with pc or some functions under peugeot 508
- EDC5
- My Cars: Citroen C5 RHR AM6
- x 120
That’s really interesting, do you have any pics?
Did you have to alter the wiring at all?
2006 307SW HDi 136
1992 205 GRDT - x 3
There's more info on an FB post at this link (in the C5 owners group). Basically he hacked access to the radio configuration using it's serial port on the board to configure it. I wondered about this mod myself but then I had reason to drive a rental car with the SMEG unit fitted and I simply cannot deal with touchscreen interfaces in a car!
https://www.facebook.com/groups/1958898 ... 460860697/
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I agree they are awful to use, require you to take your eyes off the road to see what you are doing. Can’t see how they were ever legal to be honest and I’m a techie!
