Hi all,
I've just bought a 2003 206 SW. I find the fact that the dipped beam goes out when the main headlights are switched on really annoying. Is rectifying this just a case of removing/bypassing a relay? And if so, which one?
Cheers, Charlie
206 Main/Dipped beam relay
Hi
A 2003 Pug 206 is gonna be multiplexed, Never EVER start bypassing relays & messing around with the wiring or trying to add things to the wiring, You can cause a whole load of EXPENSIVE damage to your car!
Do you have the H4 or H7 headlamp set up? Have a look on top of the headlights on the black plastic part, It will say H4 or H7 on them & post back.
Are the lights really going out or is it the slight delay you have noticed when you switch between dip & main?
Multiplex is Peugeots digital wiring system, If you start messing about it will end in expensive tears! I would ask the local dealer about getting the lastest software downloads for your car
Anyway a 2003 206 is still under Peugeot warranty, Make the most of it while you can
