Weird 207 problem
- My Cars: 2008 Laguna 1.5 DCi
- x 235
Weird 207 problem
My 207, 1.4 HDi is hard to start cold, a member suggested I try a jump lead between the battery negative and the engine. It made no difference so I took off the earth strap checked it for damage and and cleaned up the ends, it wasn't too dirty. I put it together followed the procedure for connecting the battery and started the car. Now I have different problem. The low fuel light stays on if the handbrake is on and the door open light stays on unless you have the drivers seat belt is plugged in. All ideas suggestions welcome. (The car was still hard to start cold, by hard I mean 4 or 5 seconds cranking as opposed to instant for the rest of the day)
Oh buggle
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5739
Re: Weird 207 problem
Smacks of a weak battery to me - if its' over 5 years old - maybe time to replace it. Weakened batteries will play havoc with car electrics.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, but be wary that although a battery may show as charging and holding a current for a while - its capacity will diminish - and over time and it will not be able to fulfill all the demands placed on it. Let us know how it goes.
- x 235
I connected the little battery meter I got in Lidl a few weeks ago It shows battery fully charged light and charging ok light, problem is it shows charging ok without the car running. I will have to get it tested properly.
Oh buggle
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes, that's the issue - what is says in the instant against how long it can hold a charge for - start the car a few times and it takes all the juice - so not a good indication.
- x 235
Are there any other earth connections apart from the gearbox one? Now when I indicate left the green lights on light blinks in sympathy. A local mechanic checked the battery he said its ok
Oh buggle
- My Cars: '95 Xantia 1.9D automatic - 118k one of two? remaining
'97 306 1.6 XS, 24k, The ex-Haynes "Max Power" display car. Bought after being written off & stripped, now being rebuilt without the wide body
'96 ZX 1.9TD SX, 81k new resurrection project saved from the scrapper - x 216
Forgive my ignorance but does the 207 have a COMM2000 or equivalent unit that could be causing the instrument issues? Or failing that, since it happened after disconnection of the battery it's like a confused BSI
'97 306 XS 1.6i, Blaze Yellow, 24k
'96 ZX SX 1.9TD rolling shell, White, 81k
- x 235
Yes it does. I disconnected the battery to check the gearbox earth I followed Marc's guide to reset the BSI.
Oh buggle
